AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "OFFICIAL" Pioneer SC-1222-K Owners Thread
"OFFICIAL" Pioneer SC-1222-K Owners Thread - Page 3
post #61 of 1014
Originally Posted by domingos38 View Post
so i just got my 1222-k .
i know it doesn't touch the sub .
so how in the hell am i going to get the sub to blend in with the rest of the system?
maybe i should of bought the onkyo 818?
Maybe we should clarify here what Advanced MCACC does. It corrects the delay, power and phase for each speaker across the full spectrum in order to make any home room as closer as possible to a THX certified environment. It tests 9 frequencies between 63Hz and 16KHz for all the channels. low frequencies below the crossover are equalized as well. Advanced MCACC does a deeper analysis than Audissey XT.
Another different subject is the fact that Pioneer is following the Dolby Labs recommendation of having a single crossover frequency since under 80-100HZ is impossible to hear the source of the soundwave because the wavelenght is several meters long and we can not detect the phase shift between both ears. Having several bass sources is useless unless you have them all in sync with the same spectrum, this is a single signal. A single bass source is better in order to maintain a controlled soundfield in the whole listening environment while requiring less power requirement. This is why THX has a single LFE channel with clear specifications in this direction.
Regards
post #62 of 1014
Originally Posted by goblue1 View Post
Does the SC1222 have anything like Audyssey Dynamic EQ or Dolby Volume to improve sound at lower volumes?
Regards
Do you know if Advanced MCACC has anything like Audyssey's Dynamic EQ to enhance sound at lower volumes? This feature really intrigues me since I have kids and sometimes watch movies while they are sleeping and don't want to turn it up too loud.
Right now, I'm deciding between the SC1222 and a Onkyo 809 since they are both about the same price right now. I think I prefer the sound from the Pio, but I like the Dynamic EQ feature and the 12v triggers in the Onkyo.
post #63 of 1014
GOBLUE,
ALC – In the Auto level control (ALC) mode, this receiver equalizes playback sound levels.
Also, the low and high frequency sounds, dialogs, surround effects, etc., that are difficult to hear when the vol- ume is low are adjusted to be optimal for the volume level. This mode is particularly optimum when listening at night.
post #64 of 1014
Originally Posted by LNEWoLF View Post
GOBLUE,
Awesome, that is exactly what I was looking for. Is ALC a setting you enable? Also, I know this is a Pio thread, but any opinion on my current 1222 vs 809 dilema?
post #65 of 1014
NO, NO, and NO unless you can get both for the same price. For a thousand times i have said that my pio1222 sounds better than my denon3311 in all aspects (mains, rears, center, and sub; yes, the sub!).
Denon 3311 has Audessey XT. The Onkyo 818 has Audessey XT32. If you can get the 818 for $600 then give it a try if the sub eq worries you. Im very convinced that Audessey XT or lesser version of Audessey XT is nothing from the other world and their "subeq" is just bullsh.....
When you run mcacc the sub also runs its impulse tests; same way as Audessey. I did a test with my Denon. I tried Hulk bluray movie on the cannon and helicopter scene with no audessey and disconected the main speakers to just hear the sub. Then did the same test after audessey calibration and guess what? The sub was almost the same; just bit boomy. I believe it adds some boost somewhere between 20hz-30hz. But I prefer a deep and tight bass and not boomy. On Pioneer the sub is very articulate, tight, deep, and not boooooooomy!
post #66 of 1014
I'm really close to getting the SC1222. I really want the SC61 (mostly for looks), but it is out of my budget. I was looking at a refurb Denon 3311, but that is gone. I'm left with the SC1222 or an Onkyo 809.
Any opinion for me here http://www.avsforum.com/t/1455656/avr-upgrade-opinions-please
post #67 of 1014
I have had the 1222 since last September and I had a question about the wireless capability. Is there a way to use one of the wireless dongles that are so much cheaper than the expensive Pioneer version? I saw that someone was using the TP-Link TL-WN722N 150Mbps and was wondering if you guys had done this and how it was configured?
post #68 of 1014
I haven't tried it because I don't need it.I prefer wired connections. But if someone tried as you specified above; then give it a try; if it does not works then return it.
post #69 of 1014
Yeah, I have run it wired, but kind of wanted to try the Ipad app to control the receiver. I don't like running the 50ft cable from my router to the receiver. I realize I could try it myself, but returning stuff can be a hassle sometimes.
post #70 of 1014
Oh; but right now you have the receiver wired to your avr? If so then all you have to do is to buy a small router. Thats what I did. My main router is at living room; my HT room is at the other side of the house; so I ran a 75 feet Ethernet STP cable from the 1/2" pvc pipe on the wall on the living room to the roof and insert it to the 1/2" pvc pipe on the HT room and problem solved! biggrin.gif Just add a small router to the ht room and now I have wireless in the whole room.
So if you have run it wired already then all you need is a router. Netgear works great when adding multiple routers; no hassle configuration; it does it automatically. I have actually 3 routers connected from the same ISP DSL Modem like in a daisy chain... Works great! biggrin.gif (One in the living room with the DSL Modem, another in the bedroom and from the bedroom another connection to the third router in the ht room).
post #71 of 1014
Be careful with your wifi network, if you overload it with your TV, Xbox360 and the SC-1222, you´ll probably be overloading the wifi network. I have a similar setup and I have a wifi router dedicated to the AV area with an Apple TV 3, a PC server, the SC-1222K, the Samsung TV, the Xbox 360 slim, the DVR. This way I only have one antenna for all the traffic, wich is much better than having several antennas for the same traffic. This way you can also use the iOS/Android application while controlling and sending AV wirelessy to the AV system..
Regards
post #72 of 1014
Dborgill; the SC61 is exactly the same as the SC-1222; Just that SC-61 is the Elite line and adds 12V Trigger; other than that is exactly the same; internally is the same construction.
The lack of 12v triggers was not enough to make me purchase the 61 over the 1222, especially at New Egg's price! I have external amps which I need to switch on with the receiver, so the lack of a switched outlet or 12v triggers is a bummer for me. I tried a number of things to get around this without success, so I turned to a 'smart' power strip.
This product DID NOT WORK as the auto-on sensitivity was hard wired way too high. Rocketfish 8 Outlet Strip
This product WORKED PERFECTLY as I could tune the auto-on sensitivity to match the 1222's current draw when off. Smart Strip SCG3
Hope this information helps someone else out!
-Mike
post #73 of 1014
I think I'm ready to pull the trigger on this. Was trying to find a SC61 at a reasonable price because of the 12v triggers and amber LEDs, but can't beat the current price on the 1222.
I have a iPhone 4 & a wireless router at home. What else will I need to stream music from my phone or external hard drive?
post #74 of 1014
GOBLUE - Yes ALC is just a mode you can select.
I don't know much about the other AVRs. Sorry i cant help you there. I am very pleased with my 1222. IMHO, it has a very clean and crisp sound. The Pioneer engineers did an excellent job with MCCAC auto calibration. I didn't make any changes to the calibration. Other then trying out each DSP listening mode to find out which one sounded the best to me during each media/signal input playback. the adjustments are available to tweak it as you like. Which is a huge plus. I figure that the Engineers probably spent countless hours testing different speaker configs to get the best overall results. Who knows exactly what the AVRs processing capabilities is in relation to the mic data it is receiving. The end result to me sounds VERY good. Sound quality is very subjective to the individual user. Millage may vary. The bang for the buck is most goodest to me......
Another suggestion to turn on/off additional components - I use a wireless remote controlled outlet. To turn on/off my wireless sub woofer as needed. You can get them at home depot. Some people use them to control Christmas lighting. They just plug into an outlet. Then you can plug in items you want to control. I also use them to control my lighting, wireless router and modem power on/off etc.
post #75 of 1014
If you attach the SC-1222K to the wireless router with a network cable, then you will be able to stream music from iOS/Android, use the remote control App, the Windows tune up software, you will also be able to stream music from a Windows/MacOS/Linux PC and listen to higher quality Pandora and stream radio stations.
The USB interface of the SC-1222K only supports FAT16 and FAT32 file systems, not NTFS or HFS. It is a good practice when you format an external hard drive to be FAT32 for large drives avoiding NTFS or HFS. Filesystem support is always a problem, in the Cars USB, the TV USB... Same consideration should be taken when upgrading the firmware with an USB drive, Use always a FAT16 or FAT32 filesystem.
Regards
Edited by okibcn - 2/8/13 at 11:28am
post #76 of 1014
For those who doesn´t have a 2012 Pioneer amplifier this is the look of the iPad App for the SC-1222K:
And this is the look of the iPhome/Android App:
Or watch this YouTube Video:
Regards
Edited by okibcn - 2/8/13 at 2:19pm
post #77 of 1014
Ohhhhh yeah! Will update OP tonight ---
post #78 of 1014
Hello AV Experts!
I just got my sc-1222 fro NE, and am trying to get it set up for the evening viewing. But I am not getting any sound out of my tv, only the picture.
Setup is as follows:
Cable box>HDMI>Sc-1222 (sat/cable in(hdmi#2))>HDMI out> tv.
I do get sound when I put on my external amp which is connected to the frnt L&R speakers (pre outs). But I don't want to run the amp & pre/pro when just watching the news or some other crap, but would rather the sound go up to the TV & use those speakers for casual listening....
TIA! Murf
post #79 of 1014
What if the router is too far to be connected by cable to the AVR? Is there a wireless adapter or something like that?
post #80 of 1014
Well, after an hour with the 1222-K, here are my very limited thoughts so far:
* I ran Full Auto MCACC and it made my system sound like new coming from the Marantz. The sound is more full, more dynamic and in a word, AMAZING!
* Auto MCACC does adjust your sub but like many others have said, it sets it too low. Time for javy's bass tweaks!
* My Sony Blu-Ray player is only outputting PCM and that is what is displaying on the 1222-K display. Is it possible my Blu-Ray player only outputs PCM bitstream and not direct DTS-HD or TrueHD? Should it make a difference either way?
* Can't wait to dive into the tweaks because even after MCACC and no adjustments, this receiver ROCKS!
post #81 of 1014
Regards
Thanks for your help
Always appreciated
post #82 of 1014
going to set mine up tomorrow
post #83 of 1014
I want to play with mine more.. alas, the kids are watching Brave... argh.
post #84 of 1014
javy's bass tweaks?
post #85 of 1014
Oki, I am going to add those download links to the OP. Cool?
Domingos, Javygonx has some bass tweaks. I will try and repost if he is cool with it.
post #86 of 1014
Yes, there is a wifi usb dongle, the Pioneer AS-WL300. Nonetheless I strongly recomend you to buy another wifi router, or wifi acess point, and use the ethernet port instead. It will do the job and you will be able to use it for other devices at the same time or for another device in the future. You can find a couple of models in the OP a lot cheaper than the usb dongle.
Regards
Edited by okibcn - 2/8/13 at 8:21pm
post #87 of 1014
post #88 of 1014
Strange. There MUST be a configuration option in your Blu-Ray player for the audio output. Check it and disable force PCM output.
I agree, it rocks. Superior technology, superior sound.
post #89 of 1014
I'm cool with it. On the other hand I can't wait to read the Javygonx procedure.
post #90 of 1014
Updated my firmware via USB. Took about 15 minutes but all was good. I made sure I formatted the USB stick to FAT32 and unzipped the ZIP file directly into the root of the drive. Worked like a champ.
Playing with the Javygonx bass settings.. so far so good! Awesome receiver so far. Kids have gone to bed so hard to tweak at loud settings... frown.gif
EDIT: Also figured out my Blu-Ray player issue. There is no Bitstream setting but I had to turn HD Auto Mix to OFF. Woot.
