So it seems that on the lower end of the frequency spectrum (the last couple octave) it's all about displacement.
With that in mind, the following subs seem to have really good price/performance ratios-
Infinity 1260W- 13mm Xmax, 531 cm^2 sd for $56 (best value!)
Dayton DVC385-88- 15mm Xmax, 829.6 cm^2 sd for $119
Dayton RSS460HO-4 13-18mm Xmax, 1160 cm^2 sd for $240
SI HT18D2 23.5 mm Xmax, ~1150 cm^2 sd for $240 (shipped)
It seems like the smaller drivers are a better deal, but is there more to consider in these cases?
I recently realized that 2 of the Dayton 15" DVC subs can produce more output than a single RSS460HO-4. A dual-opposed cabinet would be nice to reduce vibrations, I noticed the other day that a single 12" sub playing 20 Hz tones was rocking pretty good- and this is a 70 lb sub. Is there any downside to this configuration? It should be more sensative due to more cone area. The Fs is very similar. The RSS460HO-4 has triple shorting rings and a big 3" voicecoil, while the DVC has a small 2" voicecoil. It's also not as pretty. The Dayton Reference most likely has lower distortion.
Another concern of mine is that is appears the "dual 8 ohm coils" are actually 5.6 ohms apiece, so a pair of subs wired to "2 ohms" would actually be more like 1.4 ohms, which is 30% less than expected. Wouldn't want to fry an amp. It does look from the impedance data they provice that the minima is about 3.6 ohms in parallel around 70 Hz..
What do you think? Are looks overrated and it's all about the numbers?
Edited by djkest - 2/6/13 at 11:07am
Then down lower to the DVC15 if that's in your budget. It's a very nice driver, I personally like it but it's not as good as either of the 18's.
