AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › Gaps between rigid foam and floor
post #1 of 9
So i've got 1 room framed/insulated, but still am questioning my mold proofing techniques.
So my walls are bit over 8' by like 1-2", so the 4x8' sheets of rigid foam dont quite cover floor to ceiling.
I have my framing up 4" from the insulation, so i can visually see the gap between the floor and insulation, is that ok?
Or do i get a couple of big-gap great stuff cans and fill them up?
post #2 of 9
No point in putting any insulation on the wall if you leave a hole where the cold can come in. Rigid foam can be cut with little effort..
post #3 of 9
Agree, but the joint where walls meet the floor is not straight, and I've already framed around it.
Would Great Stuff be sufficient, that big-gap stuff expands to fit 1-2" gaps
post #4 of 9
They don't call it Great Stuff for nutin.. If it expands out, let it dry for a day or 3 then cut it flush with the rigid foam.
post #5 of 9
an old steak knife is the tool of choice here
post #6 of 9
Great stuff might have a hard time with a 2" gap, I do see they have a "big gaps" version of it, though. You might consider some pipe insulation to push in there instead, or both.
I'm not quite understanding, though, why the bottom 1" of the wall must be insulated but the 4" of concrete floor is fine? Is the floor poured on top of foamboard or ??? I did platon (think drycore) right up to the foamboard and taped that seam.
post #7 of 9
I guess i didt give enough details, the 2x4's outter edge is 4" from the insulation, in other words theres a gap between my insulation and framing.
It varies from nothing to almost 1/2" in some places, the concrete walls arent plumb.
post #8 of 9
Hey, how about a picture or 2?
post #9 of 9
That makes sense. I assume when you can "see" the gap that means it's over 1-1/2" high. Yeah, that needs to be filled in with something. I'd stuff the pipe insulation and then great stuff it in, or cut foam scraps and GS them in.
