AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Velodyne 12x15 Needs replacement 15" Passive Radiator, Need Suggestions
post #1 of 10
Hoping someone can help me out. I have a Velodyne 12x15 that needs a new 15" Passive Radiator. The current one is torn and it's not really worth trying or attempting to repair.
Looking for a recommendation for a replacement under $200. Thanks!
post #2 of 10
I'd try some place like this
http://www.simplyspeakers.com
Call them and let them know what you have. I bet you're looking at $30-40 tops.
Tom V.
post #3 of 10
Tom V.
I looked at their site and all the carry are repair kits. I want a complete replacement. Thanks though.
post #4 of 10
This is more than your entire sub but here ya go
http://www.parts-express.com/pe/showdetl.cfm?partnumber=293-682
Nashou
post #5 of 10
Here is another.
http://psicaraudio.com/products-page/passive-radiators/15-passive-radiator/
No you know you have to tune theses with weight. Not al passive will get the same results using the same weight in your Velo.
Athanasios
post #6 of 10
Nashou
That Looks like total over kill? I don't mind spending the money but It seem like more then I need. Would it be worth it in Sound quality? Better, Deeper base? Not sure I have room for it.....
I think this would be perfect but it seems to be discontinued?
Dayton Audio NS390-PR 15" Cast Frame Passive Radiator
http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-142
post #7 of 10
You need to find out what mass you need(there's a velo support thread here). You should be able to find replacements around 50 bucks.
http://showtimecaraudio.net/shop/bargains/pr-15-15-passive-radiator/
You might need to modify the cutout on your enclosure too.
Tom V.
Edited by Tom Vodhanel - 2/6/13 at 2:26pm
post #8 of 10
Is your model number VA1512? 12" woofer out 15" radiator facing down? If so I have one here that was running fine 6 months ago when I upgraded. I had to replace my 12" woofer in it about 3-4 years ago. PM me an offer if you're interested in trying to work something out. We could prolly pull parts or whatever since you won't need the box.
post #9 of 10
Steves, I also have the va1215. I changed out both the driver and the passive through PE. The passive is no longer available. The reason I changed out the driver and passive was due to rot. The foam surround on both speakers just fell apart.
If you have not already checked the driver, you should. I replaced my 12" with the Dayton Titanic.
post #10 of 10
Hi, I just came across your post regarding the passive radiator. As it turns out I have just one on eBay. If I had seen your post before putting in the ad I would have offered it to you first. It's still very functional and I was thinking about using it in a subwoofer project but I've never gotten around to it so I put it on auction with a buy-it-now price of $29.99 + a flat $10.00 shipping, so if you're still looking for one it's available at a bargain. Let me know through here or through eBay. Thanks and I hope you can use it as it's just been taking up space smile.gif
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230961461710&ssPageName=ADME:L:LCA:US:1123
