Currently own an Onkyo 818 AVR. Rated for 4,6,8ohm speaker, 135wpc 7.2, with pre-outs to upgrade to a 9.2.
Here's the issue, I purchased a pair of Martin Logan Electromotion ESLs. They are to be used with amps rated 4 or 6 but are known to dip down to 1.6ohms on higher frequencies. I can hear the sound when listening to music or playing movies but I'm wondering if I'm actually getting their full potential.
Should I add a power amp? If so, what do I look for, should the stereo amp be more than 135wpc. How does hooking up an amp to a receiver effect each other. Any suggestions??
. Now if you simply need rationalization, yes, go for it! You could also just get a two or three channel amp for the front two/three speakers to help take the load off the avr's amp (that could be more along the lines of rationalization for you
