AVS › AVS Forum › Video Components › Home Theater Computers › Blu Ray player for Silverstone GD05
post #1 of 12
Anyone know of a blu ray player that will match a silverstone GD05? Black brushed aluminum? Hunting around but not finding much
post #2 of 12
Then why not go with GD04? Almost the same as GD05, with a brushed aluminum bezel whatever optical drive you choose.
post #3 of 12
Because the gd05 can often be had for $30-$40 cheaper than the gd04.
post #4 of 12
The *current* price (shipped to my place)
SST-GD05B
? (no retailer found)
SST-GD05B-USB3.0
Amazon.com: $95
SuperBiiz.com: $114
Sundial Micro: $121
Newegg: $132.56
SST-GD04B
Fry's: $107
SST-GD04B-USB3.0
Amazon.com: $99
Sundial Micro: $121
Newegg: $125
There is no big price difference between the two *right now*. Just go with GD04, that's better cosmetically. If the op found GD05 for $30-$40 cheaper and bought it, then that's the point he has to compromise with. wink.gif
post #5 of 12
I'm going with the gd05 because I already purchased one pristine of eBay for $50.... Lol
post #6 of 12
As for your original question, there is no BD drive with a brushed aluminum bezel. The bezel of every drive is cheap plastic with lots of logos.
post #7 of 12
Well I found an elegant work around. Silverstone sells a matching slot loading bezel u an mount a slim drive in. Works perfect that's what I wanted smile.gif
Fp58 is the part
post #8 of 12
A good solution, except that generally a slim BD drive is slower than a normal one in reading BD-ROM (when ripping BD). FP58 accepts only a slot-loading drive. Among these drives, the fastest are Sony-Optiarc BC-5650H and BD-5850H, BD-ROM *DL (Dual-Layer)* read x6, but they are expensive, ~$120 or more. LG CA10N is slower (x4.8) and cheaper (~$80). Many older, cheaper drives are only read x2.
BTW a normal BD drive of BD-ROM DL read x8 can be had for $70.
Edited by renethx - 2/8/13 at 11:35pm
post #9 of 12
And all of a sudden that $50 case got expensive...
Just sayin'.
post #10 of 12
The Samsung SH-B123L has a very nice mirror effect tray door with only the bluray symbol on it, it looks very clean. The only problem is I don't think you can buy them anymore.
David
post #11 of 12
I have one of those..
post #12 of 12
Just throwing this out there, but you can try to mod a blank drive cover.
http://www.casemodgod.com/drive_stealthing.htm
You just need a black brushed alum. blank cover. The one that the GD05 comes with could work.
Also figure out a way to slide you drive back just a little bit.
