I have a question about a few receivers and if they will be powerful enough to run the things hooked up to them.
The first will be a Yamaha HTR-6030 - http://www.amazon.com/Yamaha-HTR-6030BL-5-1-Channel-Digital-Receiver/dp/B000O3OF86/ref=cm_cr_pr_product_top
Connected to it will be 2x's Infinity and a JBL Studio 1 Series SUB150P subwoofer.
http://www.amazon.com/Infinity-Primus-Two-way-Bookshelf-Satellite/dp/B0045NCB32/ref=sr_1_1?s=electronics&ie=UTF8&qid=1360250164&sr=1-1&keywords=infinity+163
http://www.newegg.com/Product/Product.aspx?Item=N82E16882665157
The other receiver will be one of the 2, I haven't decided yet. (Opinions between the 2 or something comparable in this price range *Under $300* is welcomed)
http://www.amazon.com/Yamaha-RX-V373-5-1-Channel-AV-Receiver/dp/B007JF8FD8/ref=pd_sim_e_8
Or
http://www.accessories4less.com/make-a-store/item/ONKTXNR515/Onkyo-TX-NR515-7.2-Channel-Network-A/V-Receiver/1.html
Connected this receiver will be 2x's Infinity P363's http://www.amazon.com/Infinity-Primus-P363-Three-way-Floorstanding/dp/B0046A8R3M/ref=pd_bxgy_e_img_y and a subwoofer. I'm not sure which sub yet however. I might use my old one, a Yamaha TST-SW012 http://www.amazon.com/Yamaha-YST-SW012-8-Inch-Front-Firing-Subwoofer/dp/B000TQ4D8K or look into purchasing a new sub, I was considering http://www.amazon.com/Polk-Audio-Monitor-10-Inch-Subwoofer/dp/B00030CHQ2/ref=cm_cr_pr_product_top or http://www.newegg.com/Product/Product.aspx?Item=N82E16882290130 however I am already spending a good chunk of money and I am unsure of buying a sub. I do want one, I just live in an apartment and not sure how much use I can get out of one anyways without being a disturbance
Thanks for any replys!
Or
