First off I'm on a 500.00 budget. Second its in my basement so it will be dark. Third my basement has a low celling of 6 feet and need to celling or elevated mount it. Forth it must fit on a 6x8 wall (6 feet high 8feet wide).
So with all that I will be using this for movies off Blu-Ray, playing games and streaming off xbox360, as well as cable TV with HD.
Is there a budget projector u can recommend or what resolution of a projector would u recommend. Thank u and look forward towards ur response.
