AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Where to place my MK Sound SB-12 Subwoofer?
post #1 of 6
I am a bit stumped on what to do with my new sub in my rectangular room. I have tried several different ideas and nothing seems to sound right. The room is as shaped below. The link to my sub is here
Excuse the rough drawing:
It is a rectangular room and very hard to place this big sub. Any tips are appreciated! Thanks in advance.
post #2 of 6
For optimum sub placement, one must perform the "sub crawl". Place your sub in your main listening position, put on some bass heavy music and crawl around on the floor until you find the spot with the most/cleanest bass. That is where to put your sub.
post #3 of 6
Also, if your measurements are correct, and you have an 8' ceiling, that's a 4800 cubic foot space. One 12" sub doesn't have a prayer of pressurizing that large an area. Head on over to the Subwoofer sub-forum to get more advice on what it would take.
post #4 of 6
Sorry -- Killing this duplicate thread.
THANKS ALAN!
post #5 of 6
Your trouble could be coming from the seating position. Either move the sofa off the wall some, or even better would be to put the TV on the 15' wall and have the sofa with its back towards the open kitchen.
Having a long-wall setup like you have with the seating position hard up against a wall will be creating lots of peaks and nulls in the frequency response.
post #6 of 6
the big problem i see to start
is your set up.. the front should be on the short wall..
the room acoustic would be much better..
try that out with the sub on the front short wall..
cheers
