I recently picked up a new receiver and I'm having severe problems with the calibration and the subwoofer. At the seating position, I can barely hear/feel anything, yet when I stand up, the effect is overwhelming. The ceiling above is vibrating and all you can make out is bass.
The room is mostly concrete, one wall is all wooden shelving. The sub is in an open corner with decent space on all sides. I've tried a 10" downfiring sub and a new 8" inch front firing sub, and problem is created with both. I've put thick rugs under them to try and "catch" the sound, but to no avail.
While a small issue with my old receiver (Yamaha), it was never this much of a variation. There was a subtle drift when you switched chairs side to side, but not vertical. I'm assuming the issue lies with Onkyo's Audessey tools since I've never experienced this before and the sub remains in the same place.
You also get lots of points for recommending measurements as the single BEST way to integrate subs. I've seen you do that in multiple threads. I could not agree more. There are lots of folks on these fora who don't believe in measurements, or minimize their usefulness. IMO, the measurements tell the whole story. If you get the measurements right, the sound quality will follow.
