Hello to all. I am in the process of having an entire HT installed. The installer ran Audioquest Type 2 in wall cables. Each in-wall cable has two negative and two positive cables, so one cable could potentially be used to power two separate speakers. What they are doing in order to increase the thickness (theoretically the gauge of the wire), is interwinding the two negatives together and also the two positives together; in essence to power one speaker. Not sure if this is making sense? My question is that they welded a banana plug from Audioquest to the end of the cable. The banana is bare and then the rubber boot slides over it. It basically looks like crap. As the boot is loose, it keeps sliding back and forth. I want to get different boots, and ones that the actual banana plug and boot are one integral part. Which ones do you all recommend? Also, they soldered the banana plugs to the wires. Is this the best solution, or is it better to get the locking banana plugs or the crimping type? Please advise. Thank you.
Best Banana plugs and type for the money? Please read and kindly advise.
AVS Top Picks
post #2 of 46
2/7/13 at 12:34pm
post #3 of 46
2/7/13 at 12:41pm
post #5 of 46
2/7/13 at 1:36pm
post #6 of 46
2/7/13 at 2:09pm
post #7 of 46
2/7/13 at 2:15pm
post #8 of 46
2/7/13 at 2:38pm
post #10 of 46
2/7/13 at 4:49pm
post #12 of 46
2/7/13 at 5:06pm
post #13 of 46
2/7/13 at 7:59pm
post #14 of 46
2/7/13 at 8:43pm
post #16 of 46
2/7/13 at 8:52pm
post #18 of 46
2/7/13 at 9:14pm
post #19 of 46
2/7/13 at 9:29pm
post #20 of 46
2/7/13 at 9:33pm
post #21 of 46
2/8/13 at 5:39am
post #22 of 46
2/8/13 at 5:58am
post #23 of 46
2/8/13 at 6:48am
post #25 of 46
2/8/13 at 11:27am
post #27 of 46
2/8/13 at 11:48am
post #29 of 46
2/8/13 at 2:41pm
