I'm getting back into the home theater game after a long break and dusting off some of my old equipment and need some help. My old pre-amp had switched and un-switched ac outputs so all I had to do was fire up the pre-amp and my monoblocks would fire up so i never used triggers before. I've since added the MM9000 and the 4311. The 4311 has no ac outputs. To make thing worse it appears the monoblocks and the MM9000 use different trigger jacks. Any tips on how to have everything fire up when the receiver is turned on? I will be using a harmony 890 remote to control my system. Thanks!
Images of back panels for reference:
Denon 4311
MM9000
Monoblock
Denon 4311
MM9000
Monoblock
