AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Mac Chat › EyeTV with HDHomerun: viewing on two Macs simultaneously
post #1 of 3
I've never understood something about my EyeTV and HDHomeRun combo. My HD HomeRun has two tuners (both of which are connected to an OTA antenna in the attic) and it also is connected to my CAT 5e/6 and Airport WiFi/Ethernet network.
I've purchased separate EyeTV serial numbers for three Macs here in the house, and of course, EyeTV can be accessed from various iPads and iPhones too.
But only one Mac or iOS device can access a single EyeTV tuner at any one time. When I purchased this, I thought I'd be able to watch EyeTV from two devices at any one time. Instead, if I launch EyeTV on a second device, I always get an "already in use" message. Am I doing something wrong or do I just not understand how EyeTV works?
post #2 of 3
Do you have the HD Homerun model with two coax inputs or just the single input? If it is the single input that's the newer model and El Gato says:
Each tuner can be used by different computers at the same time, or both tuners can be used by the same computer simultaneously.
here:
http://support.elgato.com/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=4187&nav=0,1,380,29,439&languageid=1&group=englishdefault
Try this, temporarily reduce all the complication you have going on: with only one instance of EyeTV open on only one of your wired Macs, are you able to record two different shows simultaneously?
Does this mean you have a single line to the single input, or are splitting the coax coming from a single antenna and running two lines to the HD Homerun or you have two antennas?
You should if your network is setup properly. I don't have an HD Homerun anymore, but back when I did, it was the earlier model with two coax inputs because I wanted one for clearQAM from cable and the other for ATSC. I was able to watch different channels on two different Macs at the same time, that's normal behavior for the Homerun so something isn't configured properly for you. One other thing to note is I never needed multiple serial numbers, I just used the same one on all the Macs in the house. This was in 10.6 and I gave up on the HDHR after that, going back to multiple EyeTV 500s instead.
I wonder if there is a bug somewhere preventing one of your tuners from being released properly, so any other device "sees" it as in use even when it's not, but first see if you can record two different shows simultaneously on that single Mac.
The most current discussion of the HDHR and Macs takes place here, George:
http://www.silicondust.com/forum2/viewforum.php?f=26
edited to add links to SiliconDust forum and El Gato's now feeble support
Edited by chefklc - 2/8/13 at 5:54am
post #3 of 3
You can watch one tuner at a time. You can't watch the same tuner on multiple computers simultaneously. If you are trying to watch on the other computer you need to hit command-o to open next live tv window if it doesn't automatically open up the second tuner.
  Back to Forum: HTPC - Mac Chat
