I saw on youtube how a guy used 80 grit glass bead sandblast media for a DIY screen. Further reading indicates that 80 grit beads are far too large. The major screen companies use smaller beads. I found that size for sale online - 240 grit. I have some big pieces of reinforced vinyl from a friend who gets used billboard signs. It is approximately the same thickness as my Elite gray screen. The uncolored side of the vinyl is white. It is also textured with a 1/4 inch mesh look from how the reinforcing fibers raise the surface. I have found I can iron those pretty flat.
My intention, once I hear from you DIY guys, is to buy a 50 lb bucket of the tiny little glass beads, and then to experiment with embedding them in flat white, gloss white, silver and also aluminum tape with a clear urethane coating. My intention is to do like square foot pieces and hang them all in front of my Elite screen at the same time to see which way I want to go.
The beads are just about the same size as the ones used on the screens you buy. I wonder if they are the same product. They are listed as smooth.
Does anyone have any thoughts or experiences with this kind of DIY project?
But I would probably use something like rigid foam board, rather than the hardboard. It looks like he used about 9 lbs of beads, so the foam would help to keep the weight down.
