AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Does Vizio make a quality product??? I am starting to think not!!!
post #1 of 6
Okay just got a vizio e470i-ao. Looked like a great deal, bought an lg and it had terrible edge bleeding. Ended up getting this vizio. I am really questioning if this is a 120hz and now the remote stopped working. New batteries, changed twice and still not working. I am really starting to question the quality of this led tv. Wanted a backlit led and thought this fit the bill. Nice picture but really concerned about this and I really think this is a 60hz panel and not a 120hz. Nice picture want to love it, but it keeps biting me. Starting to think I should order a new Samsung. I really want a Mack lit but really considering an edge lit. Any advice?
post #2 of 6
I also can't get to any of the menus to work the the different settings. I can try to use the side but it doesn't work well. I really frustrated!!! Help me!!!
post #3 of 6
I bought a Vizio 601I-A3 last Friday. Seemed fine initially. Picture was fine, etc... Now the remote only works sometimes. When you hit netflix button it takes over 3 min. to show up on the TV. None of the buttons on the tv work and few work on the remote. I will be taking back tomorrow. Oh, the SN is a 49.
post #4 of 6
Sad part is my Comcast remote works. Not my vizio remote. Only problem is that I can access any of the features. The Internet seems like a waste if the oem remote doesn't work. Help me!!!
post #5 of 6
Return it.
post #6 of 6
I plan too if I can. No remote for a least a week and now cnet is stating that this isn't really an led/120hz tv. It's a nice tv, just doesn't live up to the hype. I wish it did. Any recommendations?
