AVS › AVS Forum › Audio › DIY Speakers and Subs › Clay Pot as Sub Enclosure
post #1 of 8
Can someone comment about using sand clay pot as sub enclosure? For ported design with a strict budget.
post #2 of 8
Probably crack once you crank the sub, and mounting the driver could be tricky... I suppose you could try an epoxy seal. I'd probably just buy a sheet of 1" MDF and screw and glue together a box.
post #3 of 8
What's cheaper, a sheet of MDF or a sonotube build?
post #4 of 8
Can you comment on the SQ on this? I understand that mounting as well as porting is going to be difficult but just wanted to give it a try. I can always go back to MDF if this cracks as pot is very cheap in my area.
post #5 of 8
post #6 of 8
All that usually matters for SQ is a stiff enclosure with enough volume and proper port size. From that standpoint pot away.
post #7 of 8
It won't crack, not from the SPL inside.
Maybe an LMS Ultra might be able to manage to, if feed 4kW, but that's about the only driver that could...
post #8 of 8
I was thinking more about the vibration, not SPL, but I don't know since I've never built a sub in a clay pot.
