AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › A few more questions....
post #1 of 2
Hey. Im super new to this and trying to get everything worked out.
Payday is coming up and I wanna get this setup finalized....Here are my current questions.
1) I ordered a 16:9 100" Elite Powered screen. To my knowledge this screen has a 12V trigger but its a RJ45 jack. Not a 3.5mm like my Epson 8350 has. How can I get this to work?
2) Is Disney Wow worth it? Will my picture/sound improve using the disc. What is the diff between the 2 disc and 1 disc setup?
3) Every time I turn all my equipment off, the projector stays on because it requires a 2 button press for it to officially turn off. How can I get the Harmony remote to send the "off" command to the projector twice?
4) How often should I clean my projectors air filter?
Thanks so much!!!
post #2 of 2
Answer I can give
#2 1 disk wow has the useful disk, 2 disk set has an additional god awful newage flowers and sky video that will make you want to suck on the end of a shotgun.
Will it make a difference. The AVS 709 Disk will allow you to set the Brightness, Contrast, and shaprness. and is free (thread in calibration forum) Same as the Wow without audio. WoW is worth buying if you are new to the process of properly setting the user adjustments.. single disk only!
#4 Depends.. you have to check it and see how fast it get dirty.. I remove mine every 6 months or so and it is not normally dirty but I vacuum it anyway.
