AVS › AVS Forum › Audio › Soundbars › AVR with Boston Acoustics XS 2.1
post #1 of 3
Does anybody know if a receiver can be used with the Boston Acoustics soundware XS 2.1 digital cinema? I know this 2.1 can function on it's own (speakers are connected to subwoofer) but was wondering if had other audio components hooked into the receiver that I want to use can I connect the small satellites and subwoofer directly into the receiver?
post #2 of 3
Since this isn't a soundbar you might have better response in the Speaker or HTIB forums. In order to connect this to an AVR, you'd need an AVR that OUTPUTS audio to either digital optical, RCA analog, or 3.5mm minijack. Those are the only inputs available on the soundware.
post #3 of 3
Thanks for the response.
  Back to Forum: Soundbars
