I went and looked at this supposed 14cu ft box for sale . It looks to be built well, but not much bracing . There are 2 braces from side to side, on the top and bottom of the port . Then there are braces from the top that connect to the middle side brace, but not to the bottom of the box. No side bracing near the top from port to the top of the box. I hope its ok to post cl adds here , if not i will save the pic to . What do you guys think ? He said he used 2.5 sheets per box. The front has double 3/4 , all mdf .
http://buffalo.craigslist.org/ele/3569654872.html
We installed the rockford fosgate 1218 hx2's . They go nice and low and seem to handle all the power I can give them . The boxes do slightly vibrate when really cranking them. I had light on top of one and it moves a little when pounding. Next time i go to Walmart I will pick up a couple 10lbs of polyfill and stuff them . They have a slight echo sound when I run then at 100hz cross, hoping the fill will help. I been cranking that "scary Christmas"
