AVS › AVS Forum › AVS Forum Information › Forum Operations Center › no zoom on attached images
post #1 of 7
Zoom has stopped working on attached images.
Try this one:
Actually, that's strange. It did a full page zoom once when I was in Preview mode, but I can't get it to work again.
I'm using Firefox 18.0, no javascript turned off.
-Bill
post #2 of 7
Yep, I've already alerted the programmers.
post #3 of 7
I noticed this problem about a few days ago when I went to edit a post that had a pic embedded in a table cell in Medium size. It was now teeny-tiny with no slideshow. Re-embedded it but couldn't get it to show in "Medium" size in the table cell, and it had no slideshow to bring it up in larger size, as it normally did. Finally, moved text out of table format and embedded pic in Medium size, but still no slideshow. All using Rich Text editor.
That pic is here.
post #4 of 7
Tel them also that there is a problem when inserting a small picture. It seems that if the file size of the jpg is under ~25k, an error is generated when you attempt to upload the image . . .
post #5 of 7
OK, this should be working now...
post #6 of 7
This is a link to the 17k jpeg I had tried to insert into a post (don't ask...)
http://av-pix.com/2013/YMLHearse (1).jpg
But I got this error message:
I loaded the file into an image editor and made it larger to increase its file size, then I could upload it . . .
The only reason I thought to bloat the file size and attempt the insert again is because I remembered seeing that someone else ran into this issue several months ago.
Edit: While reviewing this post, I found that after clicking one of my inserted images it indicates that it is "Image 2 of 3". I only inserted two images in this post. I clicked the "<" and ">" controls to scroll back and forward through the "3" images and found that my post accessed wmcclain's image also. I'm not sure, but I don't think this action used to do that . . .
Edited by WS65711 - 2/8/13 at 4:42pm
post #7 of 7
Zoom is working and there is a gallery view I hadn't seen before.
Previously you could "Save as..." the image in it's original size, even if the zoom popup showed a reduced version. Now the saved version is also reduced from the original. I presume this is for storage savings? I don't blame you, if so.
-Bill
  Back to Forum: Forum Operations Center
