AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Upgrade my subwoofer or go for dual subwoofers?
post #1 of 2
So I have the Jamo sub 250 which is an 8'' subwoofer , and the room is the 4.3x4.6m and opened from one side of it. When setting the correct dial knob volume on the back of the sub , which I ended up setting it at 9 o'clock , the bass was pretty smooth but not really strong, and i suppose its because of its small driver and low watts. Sub is in the front corner , and i sit a few inches away from the back wall to avoid boomyness.
So my question is , should I go for a bigger sub (like a 12'') or another sub so I end up with 2 subwoofers?
All i want is smooth bass but yet , stronger than the current bass response i have now.
post #2 of 2
Stick to one thread, we can't be answering your questions all over the map. eek.gif
