AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Question over 2nd story media room
post #1 of 3
Hello everyone,
My wife and I are moving into our first house in about 3 weeks and somehow I was able to find a house with a 'spare' room. I was basically given complete control of this room. The only problem is it's on the 2nd story of the house!
I have been reading this site for almost 2 years and have plenty of basement build threads bookmarked/saved for doing things the right way. However, I don't recall (drinking to many beers I guess) ever seeing a thread where a room on the 2nd story was converted into a media room, so do you guys know of any?
Is it generally a bad idea to do this? Or what is everyone's thoughts on 2nd story media rooms?
Once I get into the house I plan on starting a thread with my plans and getting you guys to review them before starting, but I wanted to ask first so I could do more research about 2nd story media room's.
Thanks for any help!
post #2 of 3
Lots of us in the South have no basements, so the media room is quite often on the 2nd floor.
What's your concern? Soundproofing?
If you want a great example of a media room converted into an awesome dedicated theater, check out Spaceman's thread:
http://www.avsforum.com/t/1202525/spaceman-theater-build
That will give you an idea of what CAN be done. Now, how much you want to do, that's another question...
Jeff
post #3 of 3
Mine is on our first floor, adjacent to our living room. The only limitation is i could think of was using sand in the stage. I used minimal sound proofing, just double drywall with green glue only becuase i found this site too late.
