I'm not sure who you are asking these questions, so I'll assume me in part and reply.
Originally Posted by
Martycool007
I am sooo green when it comes to the home automation stuff that is out now as it seems to get more complicated by each passing year. So let me get this straigt, you are using relays, (which are basically just switches that turn some on & off, right?) to control when the lights come on, accompanied by some dimmer switches for the level of light. Then you are also going to be using relays for turning on your equipment, something like 16 different components, right?
I am using relays, both for power selection and control in the HT and some house functions, such as lighting in the theatre room. For example it is programmed so that when you press Play on a selection that uses video, the room lights will dim, and will ramp up when you press Pause or Stop. If I selected TT as source, none of the amps etc that run the surrounds (tri-amped) will be powered up. All power switching is done close to zero cross accounting for relay delay.
The plan is later to add mains outlet control and lighting through the rest of the apartment as I find time and need to do so. I have a friend who has build a similar system in his home, and when he's not there, lights and other devices such as radios turn on/off in a correct sequence to simulate people being there, and I'd like to add this later.
Martycool007
I have absolutely no idea what you will be doing for security management, but I am guessing that you will have hi tech cameras that will monitor everything....not sure how you are going to operate those? Also what kind of devise, or software will the security cameras feed the video into, and how do you propose to monitor this video? Also with regards to the security system, are you going to have window breakage detectors and motion sensors, and if so, how do you plan to operate and manage those with regards to how all of this fits together?
I'm doing PIR and window break, and am looking at some inexpensive commercial systems to do video. My own stand alone system will call (and later ) email if it detects. Not sure if I'll be able to integrate the two bet they might not be necessary. We'll see.
Martycool007
Are you writing the software for a DIY home automation controller, similar to a Creston? If so, how and what are you going to use for the hardware? If not, are you going to buy a controller like the Crestons that so many folks use?
Can't afford a Crestron, so I'm basically making a DIY on that does what I want, some of which is
highly specific to my my particular set up and equipment, some of which is modified to suit my needs. Total cost for everything should be under $500, plus a lot of coding and soldering, but I enjoy that anyway.
Martycool007
What is a high powered Triac and what is its purpose?
A triac is a solid state switch which can handle alternating currents, making it suitable for controlling the mains on many devices. They are also sued in some dimmers for lighting. High powered would mean one that can handle mains voltage as well as the current that the load you wish to control will draw, say 5 or 10A. Some can handle considerably more current.
Martycool007
What is a PC breakout box and what is a 10 channel 11gig router?
PC aren't natively suitable for controlling ancillary devices such as relays, so that need some sort of interface to connect to the PC via USB or RS232. These usually then let you control say 24 relays or other devices. These are used in many industrial applications worldwide.
I've never heard of a '10 channel 11gig router'. 10 channel I assume means 10 RJ45 ports but this is an uncommon configuration. Routes/switchers etc are usually in a multiple of 8 ports, 8/16/24/48 and small home/SOHO versions have 5. 11gig might refer to one of the common networking protocols
802.11g. There are faster variants such as 802.11n. Go with the fastest you can afford in a new installation to allow for longest life.
Martycool007
Sorry for all of the dumb questions but I will be remodeling a house soon and would like to have some sort of home automation like you described, and like I said, I am totally green on this!
If I was with you in person and had the floorplans and could ask questions about what you want to control and how, whether you want to use a single server and route all TV/video through the network etc it would be easier to make suggestions. FWIW I'm licensed to do this sort of work in my country.
My basic plan is to add at least one Cat6 cable and port to each room, and depending upon the room and it's use and possible uses later, I'd likely add more. You could always bring say 4 cables from each room to a central point with the switch(es) placed there and connect up the outlets you are using now. Rearrange the living room in 5 years might mean a point on the opposite wall is more convenient (no exposed cables), so all you'd need to do then is go to the 'network cupboard' and change to the correct wire. Trust me, you will regret not putting them in now when the cost will be minimal as it's easy and cheap to do before the drywall/gyprock goes up, and much more expensive later. In some cases due to the construction of the house it may be very difficult and expensive or impossible to add later without something you may not like, such as an external visible conduit.
