YMMV = your mileage may vary
As far as bracing getting in the way that kind of depends on the construction of the bracing and where it is relative to the speaker and listener. Ideally there is nothing between you and the speaker. It would not be good to place a 2x4 directly in the path between the speaker and listener. My corner speakers are slightly forward of the screen and angled. All you see are large black speaker cloth panels that are angled. Just to the inside of each horn is my screen wall framing. I've measured it with and without the screen wall and there is no difference.
No HT fun for a week, and no AE woofers shipped yet, supposed to be by the beginning of next week now.
that really stinks man, I hope the Sentinels had nothing to do with the failure.
Certainly the diaphragm alone wouldn't be close to that expensive... I hope? On well...maybe I'll give them a call. Actually, the BA measures quite well but others have said that the coated titanium supposedly imparts a sound of its own. The measurements indicate that it will go both high and low enough to match up well to SEOS 18 and TD15M.
to spring for the BMS, never mind the TAD. I remember you bringing that up though. Dude your thread is taking off, you have a lot going on over there!!
