AVS › AVS Forum › Audio › DIY Speakers and Subs › S.E.O.S.R. MEGA BUILD
S.E.O.S.R. MEGA BUILD - Page 25
post #721 of 1496
Man that looks great!
post #722 of 1496
Weighs about 165lbs like that
post #723 of 1496
Very nice! I may have to switch to black phase plugs after looking at yours.
post #724 of 1496
Yeah the black plugs are sexy.
post #725 of 1496
I'm totally going to build some of these...
post #726 of 1496
Sooooo sexy! I cannot believe these are going in my HT!! I can't wait to get them all done with duratex, all blacked out. Can't wait to hear what you think Matt, once they get fired up with some xover work in. These things are going to be ridiculous. I have been saying for two weeks that I'm going to get the surround flat packs cut, but I mean it this weekend biggrin.gif
post #727 of 1496
From what I gathered, the bms would be passive and then active for the TDs. Will there also be an all passive version? Chop, you're gonna have a great set up!
post #728 of 1496
FYI, Bob Crites sells 1.4" and 2.0" CD brackets that mount between the horn and CD, making installation easier. http://www.critesspeakers.com/
post #729 of 1496
Yes, you are correct. Once we have them set up, I will probably mess with active on the CDs too, just to see, but I have a feeling that they are going to be just fine with the passive to active combo. Not sure if someone will work up a full passive, it would eat up lots of power and be a pretty costly xover build I think, but you never know. Heck, it would be nice plug and paly though.
I can't thank Matt for all of his efforts to help me with this! He is helping me to make this all possible, where it wouldn't have been without him. He really gives selflessly to this forum and the members with the work he puts in
post #730 of 1496
Great to see your project moving along Jake. Summer seems so slow in the diy audio world sometimes so its encouraging to see you guys making big beautiful boxes.
Still looking forward to playing with my SEOS 24's.
Matt i couldnt help but notice that big DIY Synergy you have next to Jakes project. Ive just started building Bill's 3 way from the soundgroup forum.
Can you comment on your design ?
Daniel
post #731 of 1496
Here is the build thread for that one (that one starts on post 40):
http://www.avsforum.com/t/1405783/the-very-low-budget-diy-synergy-horn-build
I am happy with the way they turned out and fulfilled my expectations. I imagine they are not quite up to par with the real Danley designed Synergies, but for what I have put into them they are not bad at all.
Right now it is dormant halfway between me switching it to active/passive crossover. I can't fit them anywhere for normal use so getting them running again is low priority and I have plenty of other speakers to use biggrin.gif
post #732 of 1496
post #733 of 1496
I am just looking at these and thinking about stands....I may end up making the stands out D/O Dayton 18 boxes for the front three:D I just have to rework them a bit and make sure I can't mount them solidly. It would put the middle of the waveguide right about perfect, around 50".
post #734 of 1496
Daniel
I was actually thinking the same thing about the forum being slow this morning. Those synergy projects are sweet, I'd love to get a listen.
post #735 of 1496
So the surrounds are going to be 32.5" H x 16.5" W x 12.5"D including dbl baffle (1.25 with a 3/4 and 1/2 combo dbl baf). Before I go crazy trying to figure out cut dimensions and cut sheet layouts...isn't there a program that will do that if I put in the dimensions??
post #736 of 1496
Cut List will do your cut sheet layout if you know all your panel dimensions:
http://www.delphiforfun.org/Programs/cutlist.htm
post #737 of 1496
Sweeeet, thank you sir! I have them all, and did a layout of my own, but I knew it wasn't the most efficient way, so...It'll prob save me a sheet or two of 3/4
post #738 of 1496
SO, back to the ever popular amp debate real quick...anyone see any reason to use something like the LG E series amps over the EP4k?? The price difference isn't that much for similar power. I know I have been down this road, but with the discovery of these e series units and their street prices, I just had to ask
post #739 of 1496
What type of price are you talking about? And what amount of wattage are you needing?
post #740 of 1496
Street on the E8.2 is like $750 and it does 400x2....ultimately, I need between 12 and 15 channels, depending on if I run each set of 15s in each main together or individually. It will take 8 EP4ks to do it the way I want. I need around 400w per channel for each of six surrounds(maybe even a bit more). I need anywhere between 400-800 for the woofer section of each main(depending on how crazy I want to get), and about 250 per CD in each main. The CD power could change based on how much will get eaten up by the passives
post #741 of 1496
I am not sure what the LG would offer over the Behringer other than a name. I like the Crest power amps so I would have gotten a bunch of Crest Pro Lite 2.0's. I think they are $379. 540watts x2 4ohms. Crown has a few options also but I like Crest myself. Peavey's IPR lineup would be the same value also.
post #742 of 1496
http://www.behringer.com/EN/Products/NU4-6000.aspx
post #743 of 1496
The latest development in the SEOSR build...
Hayden Lee has arrived, and only 11 days late!
post #744 of 1496
Congrats!
post #745 of 1496
Congrats man!
post #746 of 1496
Congrats Jake! We are at 9 days late as of today and still waiting. biggrin.gif
post #747 of 1496
I figured something had to be happening when you disappeared for a few days, Congratulations!
post #748 of 1496
Congrats! I totally got confused by the post and did a google search thinking it was some audio consultant you were hiring smile.gif
post #749 of 1496
Thanks guys!!
Andrew, you guys will do great, hang in there!!
HTdoc, that made me laugh out loud! It was a reasonable thought given my typical track! I pictured you on google like, "what the frig is Chop doing now?!?!?!" looking for some audio mad scientist biggrin.gif she would be the worlds' smallest audio tech at 7lbs 13oz and only 19.5" tall
post #750 of 1496
Congrats! Hope everyone is healthy and sleepy!
