AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Anyone know of a 75 inch led other than samsung or sharp
post #1 of 4
Does anyone happen to know if there might be a 75 inch Samsung coming out that is not the $9000 one? I would like to get a 75 inch tv, but don't want to spend 9k. I know sharp has 70 and 80, but my impression is that the picture on those will not be as good as a Samsung and not sure about general quality. I figured Samsung would be coming out with a 75 inch in their 8000 series an be less money, but no luck yet. Any thoughts on other ideas or new releases.coming out? Thanks
post #2 of 4
how about the new vizios? 70-inch M701d ($2499), and the 80-inch M801d ($4499) edge-lit LED backlight with local dimming (16 zones) 240Hz refresh rate and passive 3D.
post #3 of 4
I thought that Vizio's were basically a step below the Sharp's as far as picture and quality. Is that not the case? Also, what is passive 3D?
post #4 of 4
not sure about picture quality. more of a value brand than top of the line. but sharp isn't known as being the best either. there aren't a lot of choices at that size.
passive 3d glasses are what you would get at an imax of other movie theater. they need no power and are cheap.
