AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Only 1 hdmi input working?
post #1 of 4
Hello everyone I'm new to this group and hope this hasn't been discussed multiple times. I just am in the process of hooking up my 6007 and am having issues. The only hdmi input that seems to be working is the cable /tv one. Is there a reason why the others don't work? Any help would be appreciated.
Gary T.
post #2 of 4
HDMI inputs should be plug-n-play when working correctly. What device(s) are you trying to connect? Have you tried doing a microprocessor reset (p. 162)? Are you using "Standard" speed or "Hi Speed" HDMI cables? Where purchased?
post #3 of 4
High speed cables and I'm trying to hook up a Marantz Blue ray player and a Wii U. I know the cables work as I can see the blue ray and wii when I plug the cable into the working input. I will try the processor reboot and let you know.
post #4 of 4
Resetting the micro processor worked like a charm. Thanks so much!
