Got another quick question. I've been working on some final measurements for the panel and I wonder if I'm going to run into an issue with getting the ports to change direction.
From left (includes the port flares) to right (only the 3"id pvc)
The 6.25" circle is the exterior port flare diameter
The 5.25" circle is the interior port flare diameter
3" is the distance between the edges of the internal port flares. Earlier you said the distance between the ports should be 3 inches. Am I interpreting this wrong (3 inches from the port opening versus 3 inches from the port flare opening)?
the 18.5" circle is for the sub
The distance from the outside of the port is 10"
The distance from the inside of the port is 3.5"
The port diameter is 3.5" external (3" internal")
I'm going to pick up some 3" pvc this weekend and I'm going to try bending the pipe with a 180 3.5" internal radius (10 inch external) bend. I was planning on this being 4 inches, which is still small) but I was measuring using the internal diameter instead of the outside diameter...
Is that going to be too tight of a bend? Is that bend even possible?
