Here's another stupid question about speaker wire. I getting new speaker I thought its a good time to upgrade the wire. The wire is about 15 years old and so is the banana plugs should I upgrade them?
Featured Stories
Speaker wire
AVS Top Picks
post #2 of 92
2/9/13 at 12:03pm
- arnyk
- Trader Feedback: 0
- Arnold B. Krueger
- offline
- 7,431 Posts. Joined 10/2002
- Select All Posts By This User
The major source of degradation of speaker wire is stiffening of the insulation, which is really a cosmetics problem.
The bananna plugs free you from worrying about the wire oxidizing.
If it ain't broke, don't fix it.
post #3 of 92
2/9/13 at 12:48pm
- Bill Fitzmaurice
- offline
- 5,212 Posts. Joined 11/2009
What is an 'upgrade' consist of? Unless your current cables are seriously undersized there's nothing to be gained.
post #4 of 92
2/9/13 at 5:28pm
- psgcdn
- Loves dynamics
- offline
- 3,786 Posts. Joined 9/2006
post #5 of 92
2/9/13 at 5:47pm
The folks who claim they hear an audible difference in speaker cable rate the % change extremely low, 3-5%. Those folks are presenting a subjective voice not based on blind tests. Please present a budget that you have set aside for the speaker wire. I purchase speaker cable based on looks, in one system white looks better my second system I use black. I chose to spend 2% of my budget for the black cable in that system and 1.6% in the other system. My black cables sound exactly the same as my white ones.
post #6 of 92
2/9/13 at 9:41pm
- Geoff4RFC
- offline
- 1,405 Posts. Joined 5/2010
I make my own speaker cables and make them look as cool as I want. There's a DIY speaker cable thread in this section, I learned a lot about making your own. The only tool I had to buy extra to get the job done was a cheap heat gun.
Monoprice 12awg cable, tech flex nylon sleeve (your choice in color and size), cable pants as an option (I've made cables with and without), and heat shrink tubing and of course your choice of termination; bananas, spades or bare wire.
A guy can get relative cheap speaker wire and make it look like very expensive cable, not only that, my cheap cable "sounds" like VERY expensive cable
post #7 of 92
2/9/13 at 10:25pm
Got pictures?
post #8 of 92
2/9/13 at 10:55pm
Where did u get the nylon sleeve?Originally Posted by Geoff4RFC
post #11 of 92
2/10/13 at 6:25am
- Bill Fitzmaurice
- offline
Don't lose track of the fact that all those cosmetic additions are just that, cosmetic, and have zero effect on the sound. Not that there's anything wrong with making your cables pretty, but ugly works just as well. I don't think all the contributors in that thread are aware of that.Originally Posted by Geoff4RFC
post #12 of 92
2/10/13 at 7:56am
- psgcdn
- Loves dynamics
- offline
post #13 of 92
2/10/13 at 9:51am
post #14 of 92
2/10/13 at 10:06am
- Geoff4RFC
- offline
I got mine from ebay. If you go look at the "Have a look at these babies" in the speaker thread, you'll be able to see the work of others, find out specific sizing for your needs etc etc. Have fun.
Really? I thought that was my point. No, wait a minute, you're wrong bill. I took $60 per 100 ft roll of 12x4, slapped a cover on it with some heat shrink, stuck some banana plugs on the end and I completly changed the sound of the wire and yes, wait for it............it now sounds like $84,000. and that's only because it was my first project. My second will sound like $200,000 cable
post #15 of 92
2/10/13 at 10:36am
- zamboniman
- offline
- 1,112 Posts. Joined 12/2001
post #16 of 92
2/10/13 at 10:45am
Furryletters on eBay will have a good selection of popular sizes and colors. There are other vendors on eBay that have additional not-so-popular colors. You can go with either 1/4" or 3/8". 100 feet of 1/4" will cover about 70 feet of 14 gauge and 3/8" will cover slightly more than what you buy. Some folks like a " shorter weave " and use 1/4" if they use a patterned flex, like the Rattlesnake pattern. The size probably won't matter for a solid color weave.
The in-wall cable that Monoprice is fine but the conductors are covered in a sheath vs. covered in molded rubber. This can leave a twist pattern in the cable on the larger gauges from 14 to 10 and up. I buy my cable from KnuKoncepts. They have an eBay store and an internet-direct store as well. Their cables are molded rubber and are perfectly round and more flexible than sheathed cable.
This picture shows the sheathed 12 gauge on top and the molded 10 gauge on bottom. The twisting is not really noticeable if the TechFlex is left a little slack.
This photo shows the KnuKonceptz 10 gauge cut-away.
Edited by jevans64 - 2/10/13 at 10:56am
post #17 of 92
2/10/13 at 10:59am
yes this wire was for the center channelthank you
post #18 of 92
2/10/13 at 11:18am
- Bill Fitzmaurice
- offline
The sad fact is that you're right, only what the suckers who buy high priced cables don't realize is that an $84,000 cable sounds just like a $30 cable. Originally Posted by Geoff4RFC
post #19 of 92
2/10/13 at 1:48pm
- josh6113
- offline
- 615 Posts. Joined 7/2008
post #20 of 92
2/10/13 at 3:35pm
- Bill Fitzmaurice
- offline
Unless you conduct a properly controlled double-blind testing session, and then post repeatable verifiable measurements, don't bother. That is the only scientifically valid method of making comparisons, and this is the Audio Visual Science forum.
post #21 of 92
2/10/13 at 4:11pm
- josh6113
- offline
My video review will just be for fun...not a critical test...and I would love to know if you believe in god...if you do Prove it...
...not everything in life has to have proof...its human nature to need to see in order to believe...
post #22 of 92
2/10/13 at 4:58pm
- Geoff4RFC
- offline
I think there may be a "slight" difference here; to believe in God requires faith, faith is the substance of things not seen, the evidence of things hoped for.
I don't see where faith plays into how two different types of cable can change the sound when it's job is to carry current from the source to the output. A different speaker may produce a different sound, a cables job is to allow current to flow from one place to another.
I personally have faith in the work of the cross, I don't have faith that this cable or that will change the way my speaker sounds, sorry.
post #23 of 92
2/10/13 at 5:05pm
- josh6113
- offline
Its a metaphore... And you just proved my point...thank you...
post #24 of 92
2/10/13 at 7:54pm
- Geoff4RFC
- offline
Really, because learning how to read english and having a post H.S. education leads me to understand that your statement "Cables can and do have a certain sound signature to them" and me saying speakers make the sound and cables just carry the current to them so they can, have no "point" connection at all, but instead an indifference.
post #25 of 92
2/10/13 at 8:13pm
- josh6113
- offline
Bashing doesn't effect me and if you want to say something to me send me a P.M....and I won't try to convince you...cables do have sonic differenses...BUT the differenses are often small and equipment dependant.Originally Posted by Geoff4RFC
post #26 of 92
2/10/13 at 9:27pm
What's always struck me as funny is that, as expensive as the high-end cable market is, I've never once seen actual empirical measurements between one cable and the next. A cynical observation would note it's probably so said cable manufacturers don't have to try and explain away identical measurements between their cables and the original cables, and so the guy who just spent $7,500 on a power cable doesn't have to deal with active denial that he spent his money on something that imparted absolutely no measurable difference. The descriptive words for the expensive cables also tend to run the same, regardless of what it's for (headphones, speakers, interconnects, power, whatever) - they add "sparkle" or "airiness" or any of the group of words that can be bluntly summarized as "elf farts". Light, delicate, and musical.
If cables do make a difference, I think it's less than (or at the most, equal to) the components in the equipment make - after all, if cable which carries a current can change sound, then surely the differences in one manufacturer's batch of resistors or capacitors and a later would also cause a change in the sound? That never seems to come up, though.
I'd say buy whatever decent set of cables seems good to you - or for those unfortunately stuck with a wife whose aesthetic demands outweigh all else, whatever she likes.
post #27 of 92
2/10/13 at 9:36pm
- josh6113
- offline
Well said...and the price that these multi thousand dollar cables are rediculious. As for me the most I've ever spent on cable was 100 dollars but I started way at the cheap low end and as I moved up and tried all sorts of cable I notices differences through most of them.Originally Posted by DemonicLemming
post #28 of 92
2/11/13 at 6:00am
- Bill Fitzmaurice
- offline
I have. There are three factors that determine cable performance: resistance, capacitance and inductance. That's it, anything and everything else that the cable mountebanks claim influences the result is pure unadulterated bunk.Where resistance is concerned all cables of the same material and gauge will have exactly the same resistance.
Where exotic materials are concerned there's nothing to be gained. Silver, the most commonly used 'high end' conductor has 5% less resistance than copper. But to get the same results with copper as silver you simply use either 5% larger gauge, or 5% shorter length.
Capacitance and inductance are affected by the size and dielectric properties of the insulation. But more expensive insulations work no better than inexpensive insulations.
There are measurable differences in capacitance and inductance between different cables. But those differences are never related to price. Some of the lowest measured capacitance and inductance are found in the least expensive wire available, while some of the worst measured capacitance and inductance are found in the most expensive wire available.
As for what really counts, can you hear a difference, in blind testing even self-proclaimed Golden Ears have never been able to correctly identify cables by brand, price or performance with any higher degree of accuracy than pure chance. That's because even though differences can be measured the measuring gear has a degree of accuracy a few orders of magnitude higher than the human ear. When a cable is so poor that it's audible it's simply defective.
post #29 of 92
2/11/13 at 6:22am
- arnyk
- Arnold B. Krueger
- offline
Yes, copper gets old and tired from all those electrons flowing through it. ;-)
Of course one irony is that since audio is AC, there is only negligible net flow of electrons. The same electrons have been shuttling back and forth for years!
Around here most of the power lines were put in the the 1950s and have been in place for over 60 years. I've noticed that power lines from the 1920s and 1930s often have their insulation falling off due to old age.
Oh and a hearty +1 to what Bill says in post #28.
post #30 of 92
2/11/13 at 7:42am
- smudge981
- offline
- 1,361 Posts. Joined 1/2011
Wait minute! I was told there'd be no math!
In high school science, we called the three properties of impedance the R.I.C. or "rice rule"...resistance, inductance, and capacitance...resistance being the main culprit. Keep it under 5% and you're fine. Oxygen-free copper, silver, Monster cables? Go for it if it makes you feel any better. Your money. Diminished returns, thy name is speaker wire.
- Speaker wire
AVS Top Picks
Currently, there are 1578 Active Users
(350 Members and 1228 Guests)
Recent Discussions
- › Official Panasonic VT60/VT65 Series Discussion Thread [No Street... 32 seconds ago
- › New JVC DLA-X75R/DLA-RS56 $7,999 projector with 3D RF glasses and... 54 seconds ago
- › The "Official" Denon AVR-4311CI/AVR-A100 thread [NO PRICE TALK] 1 minute ago
- › American Idol Season 12 (2013) 2 minutes ago
- › Official Samsung PNxxF8500 Series Discussion Thread [No Street... 2 minutes ago
- › Panasonic ST30 Repair Help Please 2 minutes ago
- › Questions by someone in my family (Ceton - HdHomeRun Prime -... 3 minutes ago
- › Completely new room plans - What to do now with the two SI HT 18s I... 4 minutes ago
- › The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's... 4 minutes ago
- › Audio source for Soundbar AV system? 4 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
