AVS › AVS Forum › Audio › 2 Channel Audio › Turntable - Rega vs Project
Turntable - Rega vs Project - Page 2
post #31 of 38
Sheesh... I put a lot of thought into my reply; I'm sorry you didn't find it useful.
To answer your question, there isn't likely to be much difference b/w two properly functioning, properly setup well-engineered turntables. My hunch is that the difference b/w my Technics SL1200mk2 and your friends uber-expensive table is apt to be negligible in a true blinded A/B comparison. Why?? Because the biggest engineering challenges that turntables present have largely been solved. The limiting factor is the noisy interaction b/w the stylus and the record. ..Plain and simple. ..I suggested the Technics b/c it is as simple to operate, easy to maintain, easy to find parts for; and does have a sonic advantage over belt-driven tables in that it maintains speed far better. So what hasn't been answered?
post #32 of 38
Most of the difference is in the cartridge you choose. "How different" is relative and will be different for every person. That said, different designs can make a difference in performance as well--suspension vs fixed, belt vs. direct drive and where the table is placed and how much vibration it has to dissipate.
The Rega RP6 is $1500 w/o cart. It has a bunch of upgrades over the RP3 ($900) including the speed controller. You get the better plinth, better platter, different brace, much better metal subplatter, upgraded isolation feet, gloss finish, etc.
I would rather own the RP3 over the Pro-Ject at half the price.
As others have said if you are prepared to spend closer to $2K then there are other options besides the Rega--though there is nothing wrong with the tables.
The advantage of using Rega carts is the three point mounting (starting from the Elys up). If you aren't having the table professionally set up and don't want to fuss with it yourself then the only adjustment you make with these models is tracking force. There is no VTA, no azimuth, no lateral adjustment, etc. If you buy the table as a package then the cart is even mounted for you!
Others may have other cartridges that they feel perform better. Cartridges are like speakers--everyone has their preference. In general, if you spend more and choose wisely you can get a better performing cart.
I see you are in New York and am surprised that there are no audio shops you can frequent. Where do you plan to buy the table?
B.
post #33 of 38
Originally Posted by SimpleTheater View Post
I'm a bit older than your average "just getting into vinyl" guy. That avatar of mine was my first stereo receiver (a technics SA5370), circa 1977. I'm planning a new home theater and a separate dedicated listening room. $2000 fits will within my budget.
Thanks for the clarification. In your case the VPI might be a good choice then.
post #34 of 38
I found it extremely useful. Thank you. My other post was meant only for those other two and my words made it seem as if it was for everyone. I apologize.
post #35 of 38
B.
Upstate NY. I'm thinking NeedleDoctor, unless I get that ClearAudio turntable used.
post #36 of 38
Have you made your choice yet then??
I'm looking at the R6 and R3 also, but also have an old Bang and Olufsen Beogram 3000 which I could get repaired, so am slightly torn with regards to my options.
Any of the older audiophile vinyl users have any comparable experience of say a Beogram vs a rega and whether there is any contest? The B and O has a transcendental arm which 'follows the grooves' instead of a fixed arm that rotates across the record. Its also aesthetically quite nice to look at, downsides the cartridges are pricey and spare parts rare,.
If anyone could make suggestions based on experience I would be greatful. If there is no contest between such units re rega 3/ 6 and the B&O then also this would be useful.
Thanks guys,
Magnus, UK
post #37 of 38
After the ClearAudio TT failed to come through, I've done nothing. The itch is gone and I've been busy watching movies and listening to SACD's with my new Paradigm Sigs. I'm certain when the itch comes next I'll get a TT. I would most likely get the Rega R3.
post #38 of 38
I wonder why there's been no mention of Thorens TD190, TD240, or TD295? Seems like these should be included on the short list of sub-$1200 options.
