I would like to see if someone can recommend a solid pair of FRONT speakers to go with the system I already have. This is going to be the final purchase I will make for my HT for a few years. I can't spend more than $175 for the pair and I am open to used and refurbished.
The system will be used primarily for xbox 360 gaming and blu ray. Very little music.
The Denon puts out 105 w nominal at 8ohm, and the speakers I already have max at 125w @ 8ohm
The main focus will be on finding speakers that best MATCH the speakers I already have, while adding some depth to the sound.
NOTE: I already have 6 TL2 loud speakers, so I will be replacing two of them with these new bookshelf fronts...soooo just keeping what I already have is also an option if that's what you think will sound best. Thank you.
Do I have to then change the center speaker no matter what if I change the fronts?
Room is 20x15 ish 7.1 system
