Working on designing another enclosure which will consist of dual 12" subs and dual PR's. after a lot of modeling I'm showing a really flat response from around 20hz to 32hz. Not having really worked with having to fix a response like this what suggestion would you have the response is low about 8db at 20hz and drops down to only about 3db at 32hz. If an eq inline will help let me know what suggestions you may have. I haven't been building long but this is a pretty flat curve that I want to be able to work out before I begin the build I don't believe it's a big deal to fix but need a little help thanks!
