Hello everyone.
I have been using tmt5 for over a year with limited to no problems.
I do have 2 disks that will not play.
It will not play mad men season 5 Blu Ray, shows a screen that says searching for updates then never gets to the menu.
This happens on an ISO rip, the DISK or FOLDER format.
I have a similar issue with the new ALEX CROSS Blu Ray
this one won't play folder, iso or the disk itself, the disk works in my blu ray player
it hangs during the blu spinning busy wheel...
any suggestions... seems like it just crashes on both of these loading the menu off of the discs...
thanks,
Kevin
thanks,
Kevin
