AVS › AVS Forum › AVS Forum Information › Forum Operations Center › How can I undo a "blocked member"?
post #1 of 5
I cannot view a certain members posts because I unknowingly somehow "blocked" the member.
What procedure do I need to follow to "unblock" this member?
post #2 of 5
Just click on their name & unblock.
post #3 of 5
It worked! Thanks for the help.
post #4 of 5
If I may piggy-back a suggestion, would it be possible to change (or add a profile setting that allows you to change) the current default, which shows posts from blocked members in subscribed threads as "unread"?
Many times I clicked on a subscribed thread, only to find out that the only new post is from a member I blocked.
post #5 of 5
There's nothing for that now, but worth a suggestion for the future.
  Back to Forum: Forum Operations Center
