Hi All -
I built my HTPC about 2.5 years ago with the help of this forum. I've received a lot of joy from it, though it is now starting to show its age.
I'm looking to build a new HTPC. Looked through the forums and in need of some recommendations.
Goals:
I don't build computers often so my knowledge base has a few holes. Thanks all!
Goals:
- Computer will only be for HTPC use, though looking for a fast CPU as I want minimize wait time when encoding video files and I may add a media center extender in the future
- Will look to use the onboard GPU (not purchase a separate one)
- Not looking to overclock
- Need recommendations on memory
- Recommendations for keeping the setup cool. My case does vent well.
- Should be compatible with Ceton InfiniTV 4
