AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Combine Two A/V Sources Into One Input (without a switch box)
post #1 of 13
I'm looking to combine 2 "Component" sources into 1 input on the back of my TV, and I would hate to be forced to buy a Selector-Switch Box just to do something so simple for only 2 devices. I know that using a standing Y-Cable will cause interference resulting in a dark or distorted image (even with only 1 source turned on) and that in order to fix this, there would need to be some kind of ohm resistance built into the splitter I think?
I've searched like crazy and all I can find is this- http://www.avsforum.com/t/1202569/combine-via-y-cables-two-rca-outputs-into-one-input-okay - and thus I cannot find one real answer or "Combiner Cable" that can do what I want to do.
Surely something exists that would allow what I want to do. Can anyone point me to a splitter cable that has some kind of ohm resistance built in to avoid interference?
post #2 of 13
Are the sources really "component video"? Actually, in this case if you can run HDMI instead there are auto-switching solutions. 2 HDMI devices in, one output which will auto-select based on power-on/off or port prioritization... I bought one off Amazon for like $10 and while it was a bit flaky to setup (didn't like a particular input on a Samsung TV), after some trial-and-error it works solid.
Jeff
post #3 of 13
No, they don't exist. Use a switch.
post #4 of 13
Jeff
Yes it truly is component. The particular TV in question does only component or composite.
post #5 of 13
Monoprice has a great 4-input component video switch with IR control for <$20... It will even learn an IR code for another device, so you can make the switching work with most any remote...
post #6 of 13
After reading many reviews of alot of these kind of devices, almost all of them seem to degrade the picture quality. This seems to be the trend for the powered ones, unlike the non-powered ones. I wonder why they all seem to have this problem?
post #7 of 13
Not as much as your idea of paralleling two video sources.
they don't
post #8 of 13
I have one of these Monoprice units, never noticed any picture issues, nor would I expect one. Simple switches won't do anything to affect image quality.
post #9 of 13
Originally Posted by SAM64 View Post
they don't
Yes they do, read the negative reviews on most of the powered ones and see for yourself. (amazon.com). Heck I had two powered one's 8 or so years ago and they distorted the picture quality, so I sent them back. Yet two other Sony models (non-powered) displayed the picture quality as-is. Unfortunately they are composite-s-video only.
post #10 of 13
Oranges vs. kiwis, then.
Just get the Monoprice one like I did, then, which has 91% positive reviews... And you can always return it.
post #11 of 13
Another vote for the Monoprice one. I've been using mine for 6 or 7 years. Along with my Harmony remote, you wouldn't even know it's there smile.gif
post #12 of 13
Yes they do,
No, they don't. 'ALL' powered switchers do not have problems...users like you do.
post #13 of 13
Back in the day, a friend had a passive one for cable, PS3, and XBOX, and it was fine, no degradation. A good quality one should be fine.
  Back to Forum: Home A/V Distribution
