AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Pioneer SP-PK52FS with Denon AVR-2113 or the AVR-1713?
post #1 of 8
Hi I am new to the forum and just recently bought the Pioneer SP-PK52FS 5.1 system but I am still undecided about what receiver to buy. I narrowed it down to the denon AVR-2113 or the avr-1713. Would I see a difference in sound quality from buying the 2113 over the 1713 with these speakers? Also I am not planing to update to a 7.1 system, and I don't care about upscaling since every thing i run is at 1080p, nor do i care about 4k. I only care about sound quality. I will only have the receiver connected to my htpc via hdmi mostly for blu-ray, and some music once in a while. I know the 2113 has 95 wpc compared to 80 wpc from the 1713, will I be able to hear a difference with that? I do like to hear my blu-rays loud so I am not sure if the 1713 will be powerful enough. The room size is 18x12
Edited by johnscare84 - 2/11/13 at 7:03am
post #2 of 8
The extra 15 watts per channel rating will provide an inaudibly slight increase in the maximum volume your system can put out without noticeable distortion. A fraction of a decibel at best.
post #3 of 8
is that worth the $120 increase of the 2113 vs the 1713?
post #4 of 8
In and of itself? To me?
No.
post #5 of 8
Howdy Johnscare84 and welcome to AVS,
A couple questions, What is your budget and have you looked at anything other than Denon AVRs?
post #6 of 8
I would say about $500, but I would like to spend less because I am more into sound quality than into features. I wont be streaming anything nor do I have any apple products. I am justing using it for my htpc with xbmc. I have looked at pioneer and onkyo receivers also, but people have been telling me if you are only looking for sound quality and don't care about features then go with a denon receiver with Audyssey MultEQ XT especially if you are a beginner since it will take care of the sub for me. Plus 2 year warranty is a plus.
post #7 of 8
If you only need 5.1, then the 1713 has the same Audyssey MultEQ XT as does the 2113CI and so the 1713 should serve you very well.
post #8 of 8
ok, have you looked at the SC-1222-k it can be found for around $500.oo and it had the class D amps
