AVS › AVS Forum › 3D Central › 3D Tech Talk › Clip on 3d glasses that work with Optoma emitter?
post #1 of 8
Does anyone know a glasses that will work with this? http://www.bhphotovideo.com/bnh/controller/home?O=&sku=891494&Q=&is=REG&A=details
Wearing 2 pairs is not a good as I would like, and I have seen other glasses that clip onto your own glasses.
Any thoughts?
post #2 of 8
Sorry, but with that emitter, as I pointed out in your other thread, you are limited to the glasses produced by Bit Cauldron, and as far as I know, none of them are clip-ons. I suggest you contact Bit Cauldron directly to discuss your options.
post #3 of 8
There is no such thing as clip-on active 3D glasses that I am aware of at this moment in time. Your best bet is to buy an extra cheapo pair of your prescription lenses and attach them to inside of the 3D glasses somehow.
Here is a company that makes prescription inserts for active glasses. I'm sure if you contact them they can makes ones that fit the glasses that you buy. It is going to cost you.
http://www.rx3doptics.com/products
post #4 of 8
I thought so, too. However, "Big River" has a 3rd party clip-on set for DLPLink listed on their website. But it's the only such active glasses I could find. Personally, I think clip-on active glasses would become uncomfortable very quickly due to their extra weight sitting right on the bridge of one's nose.
post #5 of 8
There you go, I never saw these before:
http://www.amazon.com/3DTV-Corp-Dlp-link-Projectors-Mitsubishi/dp/B00AVGFPHG/
For $50 they are worth a shot. I can vouch for 3DTV corp - I purchased glasses from them in the past and their support was fantastic.
post #6 of 8
Unfortunately, the OP is using an Optoma projector that came with an RF emitter and glasses kit. I don't know if DLPLink glasses would work with his projector.
Edit: After checking the Optoma website, it looks as though all their current HT projectors are DLP, but not all are 3D-ready. It'll depend on the model he has. The HD-33 has 3D sync selections for either DLPLink or VESA (the RF emitter).
Edited by Rolls-Royce - 2/12/13 at 11:41am
post #7 of 8
I am pretty sure all Optoma 3D projectors support DLP Link glasses. The OP didn't tell us the model of his projector so we can't be sure.
Optoma HD33 - supports DLP Link glasses
Optoma HD66 - supports DLP Link glasses
Optoma Gaming projectors support DLP Link
My TV supports DLP Link and also has a VESA port for other types of glasses.
post #8 of 8
I'm sure you're right. The HD33 was the first 3D-ready projector in their lineup, and the only one I looked at. I should've said, "For example, the HD33 has..." smile.gif
  Back to Forum: 3D Tech Talk
