AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Samsung 46" help please
post #1 of 2
Model LN-T4661F
Have a white screen. I get the Samsung sound when you turn on the tv. I can faintly see the menu. When I plug in coax or hdmi from the cable box I get no picture or sound. The same cable box is working fine with another HD TV.
Here is what I have done:
swapped T-Conn card and no change
swapped main board (board with HDMI's, RCA jacks etc) and no change
I'm thinking maybe swap the power supply next? The caps don't look bad and it has no problem turning on.
Any input on this would be appreciated, thanks
9803-0.jpg 171k .jpg file
post #2 of 2
Anyone think a power supply will fix the problem? Any input?
