I woke up the other day to the smell of burnt plastic. I didn't hear any noises or see any smoke and my smoke alarms didn't go off. I thought it could be my neighbor since I live in a duplex. A couple of days later I went into my second bedroom to listen to some music. My sub was dead and no LED on the back. Next I pulled the fuse and it was blown. I had a spare fuse so I put it in and the LED would switch from red to green but still no sound. A few days later I pulled the amp and was shocked at what I found. A capacitor had exploded and caught on fire. It leaked onto the circuit board below it and burned completely through the board. Many of the surrounding areas where covered in soot as you can see in the pictures. A few spots on the MDF around the cut out for the amp have burn marks in them. The MDF was very close to catching on fire. In total I have five subwoofers in standby mode in my house. Four in my main theater and one in my second bedroom. They all have the same Bash amplifier. I'm worried this could happen again if I leave any of these amplifiers in standby mode. I think one of my only choices is to turn all of them on and off manually after every use to prevent burning my house down. The other option I'm considering is removing all of the plate amplifiers and using a large pro amplifier I have sitting around to power all four subs. I think I could wire two subs in parallel on each channel on my two channel pro amplifier. I don't want to alarm everyone but this is dangerous.
Amp fire 1.jpg 617k .jpg file
Amp fire 2.jpg 575k .jpg file
Amp fire 3.jpg 714k .jpg file
