Originally Posted by
frankie2075
auburnu008
For less than $3000 you could do (8) Stereo Integrity sealed 18's with either a clone or 2 inuke 3000's powering them. That would destroy anything on your list in the OP.
What os stereo integrity? Subs?
http://www.avsforum.com/t/1430438/stereo-integritys-new-ht-subwoofer/1470
Here are Gorilla's 4 dual opposed (8 drivers). They are sick, that man is into some serious high output + high performance. His subs are called the silverbacks and if you can DIY straight copying his is not a bad route to go. I suspect he will offer up all the free advice you can handle.
http://www.avsforum.com/t/1435795/first-diy-project-for-a-guy-looking-to-upgrade-multiple-sealed-18s/870
Popalock is doing a build with something like 16 of them. There's a pic in rilla's thread after pop went down to NC to pick up his woofers and a bunch for some other folks and he standing in front of a massive wall of woofers in box's, pretty sweet.
If I understand correctly, and I may not, They are not as high end as say the LMS 5400 driver but they are very good and a lot of the DIY'rs think they are such high value that they just throw a bunch of woofers at the problem so it is a very low distortion situation and the multiple woofers flatten the response. They are achieving very high end results for some of the smallest prices around. The LMS is expensive.
