AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Kenwood Sub......
Kenwood Sub......
post #1 of 11
Hello. I have an unusual request. I bought a Kenwood surround sound system a long long time ago. I think it was somewhere around 1994. Now I still have all the components and speakers. The subwoofer is one of those that you have to run speaker wire to and from the sub.
I want to use the sub on my onkyo that I have outback in the patio. But I do not know if I can connect it to the onkyo. the sub does not have an rca connection to just simply run from the sub to the back of the onkyo. How can I hook it up to it??
It is a kr-200ht. thx in advance.
post #2 of 11
Bump.
Anyone?
post #3 of 11
Is your sub self-powered ("active")? If yes, run wires:
- from your AVR's L+R speaker-level outputs to the sub's L+R speaker-level inputs;
- from the sub's L+R speaker-level outputs to the L+R speakers.
And, in the AVR's speaker set-up menu, set "subwoofer" to "none".
If your sub is not self-powered ("passive"), you'll need a separate subwoofer amp. Run an RCA connection from your AVR's subwoofer output to the subwoofer amp, and run wires from the subwoofer amp to your sub.
post #4 of 11
Actually I am trying to hook it up outside on my onkyo ht-r540. We use it when we are BBQ outside. Can I hook it up to the onkyo? Right now I got my left and right and center speakers hooked up. Thx.
post #5 of 11
There is no RCA connection on the back.
post #6 of 11
Ok. Got it to work. But it is not putting out much power. I barely feel it. Any ideas??
post #7 of 11
You mentioned that in post #1. Please re-read post #3.
Ok. Got it to work.
How did you get it to work? If it's a passive sub and your using your Onkyo AVR to power it, that's a bad idea.
post #8 of 11
You need a separate amplifier to power it.
post #9 of 11
Why is it a bad idea??
post #10 of 11
Because it won't work. You need a separate amplifier.
post #11 of 11
K. I will stop by best buy. Thx.
