AVS › AVS Forum › Audio › 2 Channel Audio › Computer audio $500-$600
post #1 of 26
Greetings all. I'm sure this is asked periodically so I apologize in advance if you're sick of seeing yet another "What computer speakers should I get?" thread. I searched but didn't find anything that answered my questions. I promise I did. So, here goes:
Budget: $500-$600ish
Purpose: Some music use (lossy) though mostly interested in just a general all around improvement in audio quality. (I'll listed to music on the 5.2 system in main listening room.)
Gear: New iMac. That's it. No desire for a sub, so keeping it strictly 2.0.
Goal: Good audio, smallish footprint, keep it clean (read: minimize cords), relatively low maintenance (read: dummy proof)
Aesthetic: Design is not paramount but WAF is a factor
Room: My office is just a large closet right now so not much cubic footage but I'll be moving soon so hoping to "future proof" it for full-size office.
Right now the short list is the Audioengine A5+ (bamboo), which is a bit larger than I want to go, and the Emotiva Airmotive 4. Second tier consideration is going to the B&W MM-1s & Swans. Any speaker recommendations? What about DAC recommendations? Given my anticipated usage is a DAC overkill?
I appreciate any input you guys could offer.
Edited by repete66211 - 2/12/13 at 5:16am
post #2 of 26
I would eliminate the B&W MM1s-too many issues. I think you meant the Airmotiv 5 correct? These would be great for your small space. However, they are $450 and that would not leave much for a DAC. The Audioengine D1 or Nuforce uDac2 would fit within your budget if you went with the Airmotivs.
post #3 of 26
You can get an emotiva 4 on their pro website for 349. I think you'd be happy with either the audioengine a5 or the emotivas. I have the small audioengine 2s and they are great.
Given the use, the dac might be overkill. Try it without and see what you think.
post #4 of 26
Yeah, I've read about a widespread buzzing issue. Not worth taking a chance at that price tag.
Actually, since the Audioengine A5+ and Airmotiv 5 are both pushing the limits on available space and the Audioengine A2 seems a bit too small the Airmotive 4 seemed to be a good compromise.
Those were the two DACs I was looking at.
I think you may be right. Thanks!
post #5 of 26
Behringer B2031A. It is my idea of a small footprint speaker, but it may not be yours.
Yes, at least until you find that the converters (unknown to me at this time) in your PC are sonically deficient. It is not a given that they are deficient.
In that event, the Behringer UCA 202 will likely solve the problem, and its cost won't upset the rest of your budget.
post #6 of 26
Thanks arnyk. I've seen that speaker frequently recommended. Question: How would you handle the connection from the USB or headphone jack on the iMac to the XLR or 1/4" TSR on the speakers?
post #7 of 26
I am not familiar with the Behringer. Here is what I use on my Rokits for TRS connection:
http://www.amazon.com/GLS-Audio-Y-Cable-Splitter-Cord/dp/B0062QPERU/ref=pd_ys_iyr10
post #8 of 26
That's the ticket. Thanks Ysay.
post #9 of 26
I just ordered PSB's relatively new offering into the computer speaker world. They haven't arrived yet, but they are 300 at Crutchfield which should allow for enough money to get a nice DAC along with them. There weren't a lot of reviews on them out there, so I'll be interested to see how they sound when they arrive.
post #10 of 26
Thanks. I'll check them out. They look similar in size to the Audioengine A2. Let me know how you like them.
post #11 of 26
I don't understand why most of these have the volume control on the back of the speaker. The Airmotiv is the only higher quality powered speaker I've seen with the volume on the front.
post #12 of 26
Would bookshelf speakers and a small T-amp be viable? Cambridge S30's & a Topping TP-21 amp can be had for $300. The amp is about the size of 3 blu-ray cases stacked on top of each other, so it won't take up much desk real estate. An inexpensive $20 DAC might be worthwhile since you'll probably get interference from your PC with an analogue cable. Personally I don't care for the sound of those studio monitors and prefer a little coloring in my music.
Definitive Technology Studio Monitor 450's are $280 on Newegg and go on sale for $250 if you want more bass without needing a sub. 13" x 8.4" x 11.5" isn't too big.
Edited by cyde01 - 2/12/13 at 8:17pm
post #13 of 26
I don't know either, but I suspect it's because most aren't necessarily intended to be used as computer speakers, but rather as powered/active near-field monitors. That's one extra bonus of a DAC--the volume knob on the front.
post #14 of 26
You may be right, but it's funny that Crutchfield has the Audioengines, the PSB Alpha PS1s, the Paradigm shifts, the B&Ws, and the NuForce S3-BTs in their computer speakers section. Even Audioengine's website says "join the computer audio (r)evolution". And they put the volume knob on the front of the 5+ speaker, but they're just too big for my computer space. I may end up buying the A2s and a DAC.
post #15 of 26
Check out the Vanatoo Transparent One. Stereomojo.com has a review.
post #16 of 26
I was referring to the Airmotivs, Behringer, etc. Audioengine's A5+ and A2 are definitely designed for computers. Where the volume knob is I think depends primary on size and design. The A2s and some of the others are just too small to have a knob on front and the clean lines of the B&Ws don't really allow for it. The A5s and Airmotiv 5s are about as large as I would go as well but the A2s are just too small, which is why I was considering the Airmotiv 4.
Edited by repete66211 - 2/13/13 at 7:50am
post #17 of 26
Emotiva is having a sale on refurb/demo/class B stock. The Airmotiv 4s are the perfect size so that's what I bought. The DAC is on hold until I determine if it's needed. Thanks for the input guys.
Edited by repete66211 - 2/14/13 at 9:00pm
post #18 of 26
Nice score. Enjoy!
post #19 of 26
I received the speakers today and unfortunately one of them is a dud. I have yet to hear back from Emotiva but needless to say I'm very disappointed.
EDIT: I hooked them up at lunch. I think the iMac needed a power cycle for the iMac to recognize the headphone output but when I got home from work they worked fine.
Edited by repete66211 - 3/4/13 at 6:49am
post #20 of 26
How do they sound?
post #21 of 26
It was a bit late and I have neighbors so I wasn't able to engage in any high level listening but they sound pretty good. As stated above size was a concern. Being about 50% of the volume of the Airmotiv 5, Audioengine A5+ and many of the other "nicer" computer speakers the Airmotiv 4s are an ideal compromise between sound quality and space. Budget was obviously a concern as well and at about half my projected budget I'm satisfied it was money well spent.
My "office" is nothing more than a ~30 square foot walk-in closet. I have the Airmotiv 4s at ear level about an arm's length away. They have plenty of clearance in the back. Right now they're sitting bare on my MDF desk, but I'll probably put some felt or foam under them eventually. Once I've had a chance to get used to how they sound I'll start experimenting with the high and low frequency trim controls.
Edited by repete66211 - 2/19/13 at 8:12am
post #22 of 26
Be interested in your complete impressions when done. I have the audioengine A2s, the airmotiv wasn't available when I bought them. I'm interested in the airmotiv because of the ribbons.
post #23 of 26
I haven't heard the A2s so I can't make a comparison. The Airmotiv 4s have very good clarity on the upper end and the bass is what you'd expect from a speaker of this size. Naturally, as with all speakers, get the largest you can for your given space.
Edited by repete66211 - 2/20/13 at 9:40pm
post #24 of 26
I'll endorse the Airmotiv 4's. Had a pair but gave them to my son. Have a pair of Airmotiv 5's in transit from the Emotiva warehouse sale.
post #25 of 26
I have the Airmotiv 5's but trying to figure out how to cram in a pair of Stealth 8's on stands behind my desk.
I notice considerable vibration on my MDF desk when I play the 5's at a decent volume. I was thinking about getting a pair of IsoAcoustics desktop stands to isolate the speakers from the desk.
post #26 of 26
I'm getting resonance out of the 4s as well. I'll probably pick up a pad to put them on eventually. Good luck finding room for those Stealths. They are monsters.
