hello everyone,
This weekend I follow Assassins payed procedure and it was extremely!!! helpful. I Haven't installed the codecs yet (Lav or Shark) but this device is mostly for DVR rather than ripping and storing my content.
so..after being delayed because of the snow storm this past weekend..I finally installed my Ceton infinitv 4 in my HTPC. The setup process was pretty simple and I was up and running in about 30 minutes (including activation of the card).
After watching the TV for some time (Panasonic 55gt50 using HD-Masters settings) I noticed a couple of things.
I'm pretty new to the HTPC world any help with my observations above would be greatly appreciated.
- When I change the channel for about half a second the channel is in slow motion but the audio is fine. After a half a second video is playing at normal speed. (Is this normal behavior). This is regardless if I hit the up or down channel or type in a channel number.
- The TV no longer looks as clear as when I had the Cable box plugged in... I can't point my finger on it but it looks like the HTPC is playing with the video signal before sending it to the display. Is there a way to tell the machine to just pass-thru the signal?
- My processor is running around 58-61c. with just the Power supply and Processor fan. Should I invest in another fan or are there temps normal?
- Win 7 Ultimate (64 bit)
- Intel Core i3-3225 3.3GHz Dual-Core
- ASRock Z77 Pro4-M Micro ATX LGA1155
- G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866
- Western Digital Red 2TB 3.5" 5400RPM
- Samsung 840 Series 120GB 2.5" SSD
- Silverstone ML03B HTPC
- Antec 380W ATX12V / EPS12V
