AVS › AVS Forum › Audio › Home Theater In A Box › got no sound
got no sound
post #1 of 3
anyone help, ive emailed panasonic but nothing back, i have a panasonic viera 42" hd tv. ive just bought a panasonic sound bar (sc-htb20) connected and double checked i have the wires in the correct places, with hdmi in the arc slot and still i have no sound from the bar, power light is on the sub woofer...???
post #2 of 3
Are both devices ARC capable? Try an optical cable out from the tv to the soundbar (if it has an optical in).
post #3 of 3
Assuming your TV supports ARC, be sure you have VieraLink enabled and that your speaker settings are set to home theater.
  Back to Forum: Home Theater In A Box
