AVS › AVS Forum › Video Components › Video Processors › Video Processor to Stretch PSP Component Output?
post #1 of 4
I find that I'm using my PSP more and more (mostly for the awesome SRPGs it has).
However, the PSP outputs kind of a weird resolution ("480*272, letterboxed within the 480p frame" according to what I could find on the web).
This causes the image to not fill the entire screen of my Sony 55HX929, even when I use the ZOOM mode.
So, I'm looking for a video processor which will allow me to scale the PSP's output to fill the whole screen.
Would a DVDO Edge or DVDO Edge Green do what I want? Or is that overkill?
Also, I've heard that the Edge Green has an issue with 240p material that the normal Edge doesn't have?
Any input would be welcome!
post #2 of 4
There are two PSP Scalers out there. Both from Lenkeng. One's Component to VGA (LKV7000) , the other one component to HDMI (LKV8000). Quality is quite nice. Certainly better what an Edge would make of the same signal and cheaper as well ($50-$65).
post #3 of 4
Thanks for the recommendation. The price does look appearling.
But is there a particular reason that you think it will do scaling much better than the Edge?
post #4 of 4
I can just speak from experience. If you check my site, you can see that I reviewed them all. The Edge's scaling engine isn't suited for graphic material and even less so if you apply a lot of overscan to get the 272 PSP lines to fullscreen.
If you have a VGA port on your TV Set, I would even recommend the LKV7000 oder the 8000 version.
  Back to Forum: Video Processors
