AVS › AVS Forum › Audio › Speakers › Paradigm ADP-170 replacement Foam
post #1 of 2
I have a pair of ADP-170s that I noticed were rattling and when I opened them up the foam had separated from the cone on both speakers. Talked to Paradigm for repair, but it would require shipment back to the factory and this is not worth the expense. Therefore, I would like to do a foam replacement, but the only thing I found on online that may work is the “Paradigm 5-1/4" angle attach woofer foam repair kit”. The details say it repairs the Atom, Atom v.2, CC-50, CC-150 Center Channel, WFADP 150C 9705, and many more!
The specs I found online say the ADP-170 have 5-1/2" MPC Mid/Bass Drivers. No one sells a paradigm 5 ½ repair kit, so can anyone experienced in this process assure me the 5 1/4 foam repair kit will work on the ADP-170s?
post #2 of 2
Anyone? Thanks
  Back to Forum: Speakers
