AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Samsung 60" Ghosting Issue (UN60ES6500)
post #1 of 3
Hi there,
I recently purchased a Samsung UN60ES6500 LED TV and have noticed geen-ish\grey-ish ghosting in some scenes on objects in motion.
Here is an image that illustrates the issue:
In this scene the actor is leaning forward, and as he moves forward the ghosting can be seen around the edges of his hair. When paused things look fine. Seems to happen primarily in darker scenes. (Note: this still is from the HBO show “Girls” S2E4 episode called “It’s a Shame Out Ray” at approx. 24.5 mins).
I’ve looked around online and haven’t seen other people reporting a problem quite like this although maybe I am just not using the correct terminology in my searches.
I’ve played a lot with the settings and can reduce it a bit by turning on Auto Motion Plus, but I don’t want that feature on so that doesn’t help me.
My previous set (Samsung LNT5265F 52” LCD) didn’t exhibit this problem, so if this is a normal artifact of this particular TV I’ll probably return it and find one that doesn’t have this issue.
Any advice would be appreciated. Thanks!
Settings:
Picture Mode: Movie
Backlight: 15
Contrast: 100
Brightness: 46
Sharpness: 10
Color: 50
Tint: 50/50
Dynamic Contrast: Off
Black Tone: Off
Flesh Tone: 0
RGB Off: Auto
Color Space: Auto
White Balance: 25 for all
10p White Balance (R, G, B): ON
- Interval 1: -8, -7, -7
- Interval 2: -10, -3, 2
- Interval 3: -9, -2, 6
- Interval 4: -9, -1, 8
- Interval 5: -10, 1, 10
- Interval 6: -6, 3, 10
- Interval 7: -9, 5, 10
- Interval 8: -1, 5, 8
- Interval 9: -5, 1, 6
- Interval 10: 0, 2, 0
Gamma: 0
Color Tone: Warm2
Digital Noise Filter: Off
MPEG Noise Filter: Off
HDMI Black Level: LOW
Film Mode: Auto2
Auto Motion Plus: Clear
LED Motion Plus: On
post #2 of 3
Increase brightness above 50.
Read post #1987 on this thread for details of this workaround solution.
http://www.avsforum.com/t/1395734/official-samsung-unxxeh6000-owners-thread/1980
Nevermind some ppl reporting blue/purple/dark-red blurring, because its depends what brand/model panel was used.
If the higher brightness level indeed solve this grey blur, means probably the settingpoint of the pixel overdrive circuit is too high/too low and could be probably be fixed with a FW fix.
So please report this issue to Samsung and demand a proper fix, because by that higher brightness, there is no deeper blacklevel possible!
post #3 of 3
Excellent, thanks! That is incredibly helpful.
I bumped my Brightness to 56 and that has mostly eliminated these artifacts. I also took Backlight down to 10 to offset the increased brightness. I'll probably keep doing some tweaking when I get more time, but seems like this may be an acceptable workaround.
Thanks again.
