AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Wall mount recommendation for Elite Pro 60x5fd
post #1 of 4
Hello,
My TV started to become a hazard for my 10 months old son. I want to wall mount it. Can I use a non Sharp wall mount for this TV? If so can you please recommend me a good one I can find in retailers? Also ease of installation is very important as I will be doing it myself. Ideally I would want a mount that comes with dry wall anchors.
In terms of installation tools I will need a drill, stud finder (to avoid studs?) and a screw driver. Am I missing something?
Thanks in advance.
post #2 of 4
I use this for my Elite 70 - http://simplicity.sanus.com/index.php/us/en/products/tilting-mount/SXDP3
got this at costco. No issues.
post #3 of 4
you must find the studs and mount to them.
post #4 of 4
Thanks a lot for your help. I got this one: http://m.bestbuy.com/m/e/product/detail.jsp?skuId=1048546&pid=1218213532596
It was a breeze to install. Now I regret why I waited all that time to do this smile.gif
