True, I'm not sure you can get that great of a trial in 14 days. Not that you are being unfair with 14 days.Originally Posted by spectrumbx
Sorry, but you lost me here.
FlexRAID is the most trivial to trial since it works on any existing Windows or Linux system (no need for an additional separate system) and you don't even have to use drives as unit of risk.
Unless you have a bunch of systems laying around without an OS, the complain is without base.
Best of all, once you are done, just uninstall and your data is unaffected (no messy data migration involved).
http://lmgtfy.com/?q=reiserfs+windows ...Couldn't resist Once you are done testing, what happens to your data with unRAID?
I think Unraid is a much better option if you are considering this. Any guides for this?As already stated, you can install Linux + FlexRAID on USB if you want that feel.
Originally Posted by reggie14
I'm inclined to agree with spectrumbx here. At least, I don't see a huge advantage of one over the other. If you happen to have all the equipment you need for your server, but can't decide between unRAID or FlexRAID, then you could install Linux (potentially on a flash drive), or use install Windows and just hold off on activating it.
If you don't have a server yet,it might actually be easier to test FlexRAID, since you could just use the Windows box you probably already have on your desk. I suppose you could basically try out unRAID on that machine, disconnecting any drives with data on them, but that's going to be more work (and you'd need spare drives).
You wouldn't need to disconnect current drives(you should) as long as you don't accidentally add them to the array but yes you would need a spare drive but if you are convinced you need external storage of some sort you are going to be buying drives no matter which way you go.
I've seen too many developers boasting how great their product is when it actually never sees the light of day. Until we see it, it's all BS.
